Phantom 3 memory card
Can I put a bigger sd card In my PS3 the one inside the camera was stock i have 128gb can I use it ? And or if the card is even removable it doesn't pop out when I push to eject? Please help storage running low
Yes, you can use a larger memory card. Some 128GB memory cards will work. Any of the larger memory cards listed here will definitely work.
I had to use a sewing needle to poke the end of the sd card in my P3P when it was new. Don't push the needle through the plastic just enough for it to get a grip, then pry it out. The sd card popped in and out normally after that.
You can also hook the AC to your computer using a USB cable and remove files through file manager.
