Phantom 3 crash
I crashed my phantom 3 standard and need some help. I bought a new shell and put everything together but when I put the battery in and turn it on it starts to beep and two of the motors start trying to turn. Can someone give me some advise or a place to send it off for repair?
Hello. May be the main board is damaged. Mine had the same problem and the main board was broken. You should check the main board for crack or loose soldering ? There is no gap between the shell and gyroscope and the gps so when the phantom hit the ground upside down the gps module hit de gyroscope (black box) and too bad the black box break the main board !
tpren3
