- Joined
- Jul 9, 2015
- Messages
- 163
- Reaction score
- 101
- Age
- 92
Im at 124 flights, 200Km flown, and after inspection i detected cracks on all sides, the back arms have cracks on 1 screw per arm, and the front arms have cracks on 2 motor screw mounts per arm,,,Contacted DJI and they said i've to send back the unit with a minimum turn-arround time of 8 week after it is checked in !!!!
So basicly i would have to not fly again for rest of summer, this is a BAD solution, i never touched the shell, 0 hard landing, 0 crash, I still use the same blades since day 1, they do have lot of bug kill marks but no cracks or anything....I never expected cracks to form there so it was not part of my check routine, only after reading about this I checked and found that so maybe they have been forming for a while...Here are photos of my P3A i sent to DJI with zoom on the photos with the cracks...Should i keep flying like this ? !!!! This is scary...And what they offering is unacceptable, 8 weeks turn arround is NOT how RMA for defect is suposed to work, they should send me a new complete BODY with no mistake and a box with shipping label to ship back my old body...
The scaryest pic is 9/21....look that crack OMG !
https://www.dropbox.com/sh/xv3nyg26ndw21y7/AAA_wjuk8Lg9LJtBWNUrqlkPa?dl=0
Hot glue would probably delaminate from the plastic and separate.
Update on the Bondic. I fixed my original shell and ordered a new one. The fix is holding up so well, I can't see changing the shell at this time. But when I do, I plan on using the Bondic again, no question about it.
Nice thing about the Bondic is that when it dries, you can sand it and it has an opaque appearance that blends well with the color of the phantom. It would repair that crack nicely
How long have you had it? It may be a later production run where they modified the mounting holes to overcome the cracking issues and used different screws. Don't know that for fact, but DJI certainly took the necessary manufacturing steps to correct this well known issue. Those coming off the assembly line now are surely changed for the better.I have an Advanced also. I've been checking for the cracks I've read about on this forum. But I thought the problem was regarding the two screws further back behind the motor mounts. After seeing your pictures, I looked closely at the 4 holes under the motors. Mine looks different than yours. On most holes I wouldn't be able to see cracks if they were there. My screw heads are nearly flush with the surface, and the size of the screw head is almost as big as the recess.
Most were preordered-- in May? or JuneNo, mine was early. I pre ordered. If had about 65 gentle flights.
Me also-- have not had the cracking issues yet, but I had mine apart about a week after I got it-- had to replace a motor-- so all the screws got removed and I know that I didn't over torque them, when I put them back in.Mid May
