Phantom 3 advanced app
Where can I download this app
When I try all I get is the app for the inspire
So frustrated thanks all
I copied the links from DJI's P3A Downloads page.
From the App Store for Apple Devices:
From Google Play for Android Devices:
Also, if you are interested, click here for some tips that I often share with new P3A/P3P owners.
Cheers!
Reactions: KachemakDiver
My P3Adv shows as P3Pro in app . But there is a problem at the gimbal board . When it shows as P3Pro , there is no video feed in app and light on gimbal is off . Once in a while , it starts correctly with light on gimbal and video feed in app .
It is good to watch if there is light on gimbal when drone gives no video feed.
QUOTE="seaman5705, post: 1480978, member: 123064"]
[/QUOTE]
Look on top of the gimbal board housing, does the decal say Phantom Pro? Or Phantom Advanced?
Look on the side of the camera housing, does it have a logo saying 4K? Or HD?
[/QUOTE]
Everything is "Advanced" . I have dismantled gimbal and board , even replaced it with a second hand one , but no luck(faulty board too). I have flashed firmwares , studied logs, replaced OFDM board , check/replace ribbon cable etc . My take is some fault in Ambarella or it's supply . Also , when I could boot with all working , recording video at higher resolution or lately, flashing complete firmware, will crash the gimbal leading to no light , no SD card , no video feed . And no, it is not a matter of overheating - I use fan and cold environment . Maybe bad contact of Ambarella pins or some failing voltage regulator . But I am not an electronist . Now I am waiting for a complete package camera-gimbal-board.
My post was meant more to draw attention - so many people complain about video feed , but pay no attention to all the things. When no light on gimbal led , SD card is not recognized and there is no video transmission .
Strange though, how drone is seen as Professional . Maybe because all other electronics except camera package , are identical.
Having it being recognized as a P3P was leading me to believe that it has P3P firmware installed. The P3P and P3A use the same mother board. Just gimbal boards are different.
I assure you that a large number of people have paid attention to the ‘no image transmission’ issue. There are hundreds of related posts here on the forum, and a very often referenced troubleshooting chart dedicated to this all too common problem.
Yeah , I've been through all the related posts on this forum and many other forums , Youtube etc before posting here . Nowhere I could see clearly stated this situation/conditonality or Adv drone being seen as Pro . Except if one could draw this conclusion from "troubleshooting chart" but then, the chart is more oriented on Pro drone - with faults on DaVinci etc . And when it comes to Ambarella faults , which will mostly apply to Adv drone - no solutions , or how to continue fault finding . I understand there is no solution about how to flash Ambarella . And Ambarella in Adv drone is a slightly different model compared to Pro one .
And no, firmware is for Advanced - P3S file . I've got the drone on 1.11.20 , more or less working - with same simptoms as described before . Drone could fly even when no video and being recognized as Pro. I reflashed or force flashed 1.11.20, 1.11.30 , being missleaded by all that talk about corrupt firmware - I am not sure it applies to Adv too. Results were mixed - sometimes flash will complete, sometimes will fail .Downgrading failed . Then I noticed OFDM not being detected in logs . I replaced it. Flashing became more difficult over time - mostly it will not complete because of gimbal board failing during flash - I guess the fault accentuated . With replacement gimbal board I could not flash .
This replacement board has other behaviour - it will connect/disconnect all the time . Somebody described this earlier - lots of green flashes on gimbal , then red/green sequences . It could write folders on SD but not flash - and of course it gives wrong position of gimbal arm because it is not paired with gimbal board and yaw motor . This board also has a different ID - P01069-10 - which I could barely see mentioned somewhere (not on github anyway) .
Anyway, I ended up with a clean log all modules being recognized and properly updated . If I had electronist skills , I would probably understand what is wrong , but now I am obliged to buy complete camera package . I would not risk buying only gimbal board from China, which could be faulty too - it is hard to get a refund from there .
But I have hijacked this thread . I only wanted to mention that App could see drone as other model when there are hardware faults . Most people have set the app to open automatically on mobile connection . If not , one could notice that app asks if you want to connect Inspire drone - which is strange too .
padanje
