- Joined
- Dec 27, 2017
- Messages
- 6
- Reaction score
- 1
- Age
- 49
Yes.
You have no live feed? You didn't mention that in the OP. That is a different problem.
That could be a number of things. Replacing the controller with a P2V+ V3 may or may not solve your problem.
I'm not sure where you saw 1067 meters in the specs.
You may want to do some research by using the search function here on this site. It's the little magnifying glass icon located in the upper right of your screen.
Good luck.
If DJI Assistant says the max distance is 1067m, then it's because somebody set the max distance to be 1067m. It's user defined.
