Phantom 2 controller setting wrong/messed up
Hi guys,
Hope you guys are doing fine.
Since a few week i'm the proud owner of the P2. Had many flight till yesterday. I did firmware upgrades and since then the controller setting are
messed up.
Everything is on 'normall' (in the Assistant) and the direction to fire up the the P2 are fine but then.... the right stick is for power (so it goes up). When i move the right
stick to the left or right you hear engine 'work'. When i move it downwards you hear nothing
When I move the left stick up you hear the engine work but won't generate the lift it needs (because the right stick is doing it down. When i move the left
stick to the left or right you enige will 'work' hard.
Don't know whats wrong. I tried to reverse things in the Assistant but only makes it worse :|
Need help guys! (sorry for my bad english)
Sounds as if you've accidentally changed the Tx from Mode 2 to Mode 1. Run RC Assistant and change it back to Mode 2.
You made my day HarryT! P2 is back to normall!
A big massive THANK YOU!
jorge sanchez
