Phantom 1 camera question
Downey CA
Can I fit the eflight C Go 1 camera in to the go pro case/housing that came with my Phantom? I mean does anyone know it the camera are the same size?
any help before I but it an it dosen't fit. looks like it will thou
Thanks
Jcopter
Hi I am not sure about the comparison of those two but you should be able to get the dims of both online. I did that with my SJ4000 to see if it would fit the GoPro mount and it is fine in there.
try hd 720 or 1080
no gimbal
about 150to 250 ft and about 350 m out when over waffle house / sheetz
btw FPV only good about 100 to 200 m depending on things
camera card records nicely in hd
set to 720 or 1080 p
raw video from about 2 hours ago
I have fun with this , fpv only good 100 m to 200 m , I shut my home router off so when it drops out it will reconnect instead on going router.
had to drill a couple holes In bracket and added foam, about half inch, under legs so the camera antenna clears ground.
well worth it
Nice video Thanks for the replys
I think I will get the camera it is only 59.00
sounds like a deal to me
Jcopter
sansuciboy1
