Ph2v+ no wifi
Russia
Hi guys! I just purchaise phantom2 v+, it is faulty. There is no wifi link. Copter works ok, camera recording, but no wifi at all. I turn on wifi extender, turn on copter. On range extender power led lights green, system light is constantly off. When i press reset on it - nothing happens. No wifi network found. I use wifi analyzer to search wifi networks. When i turn on copter there is wifi network without name. When i turn on extender - no wifi network appears. I know about nand flash issue, but what wrong with extender?
When you turn on the wifi extender it goes through a boot process, this can take 30 to 45 seconds. You never push the reset button unless you are ready to bind. If the second light never comes on you might have a bad extender. It sounds like you unbinded the extender. Even so, your second light should still work. Look on youtube how to bind extender on a phantom.
I did a video on a couple of things to try, the second half is rebinding and finding the MAC details
I reflashed nand in phantom. Nothing changes. I suppose my range extender is dead. System light on it always off. Power light is solid green. When i press reset - nothing happens.
Do you press and hold the reset button for 30 seconds ?
What does it mean when your system light is solid green with a system light flickering? Bad or weak signal from wifi extender?
