Pc dosent see phantom
NJ-USA
I got a "new" laptop , downloaded dji win viewer assistan 3.6 and it dosent see the phantom or the controller when I plugged it in to calibrate. Any ideas what I'm doing wrong ?
Did you also download the driver s/w?
You need to install the following:
  • Phantom 2 Vision+ Assistant Software
  • Phantom RC Assistant (for calibrating the remote control)
  • DJI WIN Driver Installer (if using Windows)
This software can be found at:
http://www.dji.com/product/phantom-2-vi ... s/download
After installing the software, do the following:
  • Connect your Phantom to your computer using the mini USB cable. The cable plugs into the Phantom on the opposite side of the battery (under the little white flap).
  • Remove the props from your Phantom (for safety reasons).
  • Turn on the Phantom remote control.
  • Turn on the Phantom (via the button on the battery).
  • Start the Phantom 2 Vision+ Assistant software.
There exist some USB cables that only deliver power (no data wires). Make sure to use one that passes both data & power.
gth723c, did you follow my exact steps above? If so, I'm assuming you already installed the driver.
rodyork, or see my post above. The 3rd step is to install the drivers 8-)
kodreed
