Haven't flown my P4P V2 in several years, but had no issues with it prior. Bought a couple of new batteries, charged them, powered everything up and all good after updating firmware(as expected), but none of the +/- 30 photos I took were saved. I see others have experienced this, but I haven't seen if there was a fix?
I used the same SD card that I used to use with it and formatted it in the drone.
Hitting the shutter button, either on the remote or in the app, it acts like it's taking the photo. And the SD card LED on the drone flashes as if it's writing to the card.
Hitting the Playback button in the bottom right corner of the app - nothing there.
Plugging the SD card into my computer shows the DCIM folder, but it's empty.
In the Flight Record I can see maybe a third of the photos I took - but I am not sure how to retrieve them and it really doesn't solve the missing photos issue.
I then tested with 3 other SD cards with the drone a mere 4-5 feet away to assure a good, strong, remote signal - same results as above.
EDITED to add that I just purchased a new Sandisk Extreme Pro 64GB Micro SD Card, formatted it in the drone and it is still acting the same.
Has a fix for this been figured out?
