P4p+ display not turning on
Has anyone had a issue wit there screen not turning on... If so... How did u fix it... Thanks...
Since no one else has replied yet, although I don't have an answer for you, I'll ask a couple questions:
What happens with the four white lights and the status indicator (steady or blinking red/green/nothing) on the bottom of the controller?
Does anything happen when you press the small button on the top right side of the screen?
Thanks for the response....
The four red dots r normal... I can even fly the drone... Always... But lately I can not get the display to turn on.... I have pressed the botton too... Nothing happens...
The thing is... If I hold the channel 1..channel 2 and shutter button the screen turns on fine... Then I can use the screen perfectly... I can even turn it of and on multiple times... And it works perfectly... But If I turn it off and let it alone for let's say I hour... Then It I can't turn turn it on again.. It's crazy...!
I'm not sure... I bought it of a third party seller 2 months ago... The box was still sealed...
All they told me is to send it in... But I was unable to fill out a repair request... I'm from Canada
Assistant 2 software, download it here:
DJI Phantom 4 Pro – Specs, Tutorials & Guides – DJI
New version is called Assistant 2 for Phantom, works with all P4 Pro models. You should be able to do a hardware reset of the drone with the software as one of the options, and or down grade, upgrade firmware of controller.
If this continues, and the drone is under warranty. I would open a case with DJI and just have them replace the monitor on the controller.
Paul C
gspr
