P4 wobble in orbit mode.
P4, 602 fw. Does this seem unsteady? Conditions where perfect. I doubt the tower would make it wobble like it did, checked logs. Just about to reflash 602 and calibrate again.
View attachment 88417View attachment 88418View attachment 88419
The up and down movement doesn't look right. When the tower moves to the left and almost seems to lean a little is something I've noticed before with mine. I'm running 602 as well.
Geo
When you are that close to a radio tower you will always run some risk of interference. Even though the tower may not have radios on your frequency there are numerous other frequencies bouncing around due to frequency interactions as well as some inducted voltages. Not saying but can't say no either.
Also remember there might be a little bit of wind higher up and you might hit downwind turbulence from the tower. I fly towers and I consider them the riskiest.
Why not doing a test orbit without the presence of the tower? To see if up and down still going on.
Don carlos
