P4 RTK not producing flight logs!
I've flown this drone on several survey flights now, but auto and manual and can't find any flight logs that I can upload to Airdata for record keeping. They must be there but I've searched all the folders (hidden as well) and can’t find them on the Drone or the built in RC controller.
Where else could they be?
Cheers
Thanks for your help, I've found them now.
I connected the DJI Assistant to the drone and put it into data retrieval mode, rebooted drone and the files became visible as FLYnnn.DAT files.
Those are the aircraft DAT files, which should be readable on the P4. They are quite large, and for most purposes the mobile device txt or DAT files are enough - unless you are using a third-party app that doesn't write standard files to the mobile device.
tom sauter
