- Joined
- Jul 7, 2016
- Messages
- 23
- Reaction score
- 1
- Age
- 76
I have a stock P4 and my range is really horrible. How can I find out which controller I have? 300 A, B, C, Etc?
Pete
Pete
Look on the back of your RC. The model is there. Mine is a GL300C.I have a stock P4 and my range is really horrible. How can I find out which controller I have? 300 A, B, C, Etc?
Pete
Mine is also the GL300C. From what I've now learned on this forum, that is the worst one for range. How can I get the 300B to replace it? Will DJI help me if I complain?Look on the back of your RC. The model is there. Mine is a GL300C.
Try some wind surfers. You can get then on Amazon for about $15.00.
They work well for me.
I tried something similar. They have aluminum instead of copper reflectors. Didn't help much. I really think the problem is the controller.Look on the back of your RC. The model is there. Mine is a GL300C.
Many other members that have other DJI aircraft have switched controllers from one to another. Some members are purchasing the Inspire remote for better range and for the HDMI output capabilities. The only difference is how the mode switch works for sport and atti modes.I tried something similar. They have aluminum instead of copper reflectors. Didn't help much. I really think the problem is the controller.
That's correct.As far as I know, the P4 remote is only available as a C model.
Did you happen to have a gimbal guard installed when this happened?very interesting thread here. I had no idea there were different controllers you could buy to use with the P4. My signal strength is terrible and have had numerous issues with it. I recently lost signal, engaged RTH and when landing the thing drops out of the air to its death. For the second time in a month. If i knew this I wouldve bought an inspire instead. P4 is a total POS
no i wouldnt fly with a gimbal guard attached, only when in storage or transportDid you happen to have a gimbal guard installed when this happened?
Ahh ok, I was referring to an aftermarket gimbal guard meant to be used while flying. Those have been known to send false signals to the drone making it think it was on the ground and shut the motors down.no i wouldnt fly with a gimbal guard attached, only when in storage or transport
Yes, we have Clean Install kit that eliminates the need to drill holes. DJI - Clean Install KitIs there a upgrade that doesn't require drilling? Like maybe one that you can just replace the stock screw in antenna
Do you need the range booster with these or are those new antenna that comes in the clean install kit? And this will give better range without the booster?Yes, we have Clean Install kit that eliminates the need to drill holes. DJI - Clean Install Kit
The clean install kit is additional to the antennas. The antennas come with cables that require you to drill holes. You do not need amplifiers with this to get more range. For me, I went from about 2500' stock to 10,000' with just the ITE-DBS02.2 antenna.Do you need the range booster with these or are those new antenna that comes in the clean install kit? And this will give better range without the booster?
