- Joined
- Jun 21, 2019
- Messages
- 229
- Reaction score
- 220
- Age
- 60
What set of pro locks you running,like in picture above or upgrade set for p4p which has a middle spring,,,those bend up tabs are terrible and always need bending to rest on prop,,if not using upgrade set you should get some,,cost is around $10 but well worth it,,better prop tension at all times...they fit p4s if that what you gotThis is the bracket set that comes with them. I have lots of props and don’t need them. More of a curiosity if I should use them.View attachment 115743
9450 is a size rather than a part number.They have the 9450 part number but I don’t believe they are DJI.
Yip sureThanks meta4. Didn’t know that.
Ianzone I just thought... I have a crashed P4P of which I can remove the locks from.
Here's a p4 low noise prop,,these 9455s,,,just for the recordThanks meta4. Didn’t know that.
Thanks!Do a bit of hunting. May be available in the us somewhere.
They are the same ones the p4p uses.
9450S Propeller Prop Mounting Plate Adapter for DJI Phantom 4 Pro+ / advanced+ | eBay
For DJI Phantom 4 Pro 9450S propeller. 2pairs Mounting Plate Adapter. 3-4 weeks to Italy Brazil.www.ebay.com
From the looks of your p4p, those prop hubs would be suspect in my world.I’ll put those on tomorrow. Late night here. Thanks for your help.
