- Joined
- Dec 10, 2016
- Messages
- 25
- Reaction score
- 2
- Age
- 45
Hello all thought I would share my experience with doing the external battery mod. Overall the job was a pain in butt, I would happily pay someone $250 to do it had I had to do it over again. Also right after I took it all apart I saw that Uavmaxx (I believe that's the company/guys name) has designed it through the battery. Anyhow splitting the case wasn't that bad, and taking it all apart wasn't to bad either, the problem is soldering in the wires, I saw where some people T spliced into the black and red wires because they didn't want to solder on the circuit board, I tried that 1st, meaning I left the wires soldered to the board and cut back some of the insulation. Total pain In the butt. Not to mention I was dissatisfied with how it looked, basically a big glob of solder that could easily rub through the other wire. So I ended up removing the black and red wires from the circuit board and soldering them while the where disconnected from the drone. I actually just ran new wires, still t spliced but was able to heat shrink and have a 1/2 way decent splice. Problem #2 was trying to flush mount the connectors to the drone also pain in the butt, I sat there for probably 2 hours with a little file and it still didn't come out the way I envisioned it. Overall I'm about %80 satisfied everything works still and I don't have wires hanging out of the drone. If anyone attempts this I will help if they have any questions and good luck
Anthony
Anthony
