P4 accessories on P4P
Italy
I'm pulling the trigger for the P4 Pro.
I have not clear if ND filters for P4 works fine also on P4P lens.
And P4 batteries (not "high capacity") work also on P4 Pro ?
Thanks...
Batteries will definitely work. Not sure about the ND filters but I think they may. Hope this helps.
Reactions: Dome
On the other hand, the main reason for the filters in the first place was to allow slower shutter speeds with video to give a more cinematic look. With the new camera in the P4P, with f stops adjustable up to f11 you may not need ND filters at all to achieve the same slower shutter speeds. And they are fully adjustable from the app.
Reactions: eneilsen
very much this... i don't know if ND's will be necessary at all, unless you want to use slow shutter speeds for stills that is.
as far as i know, the aperture is still fixed, correct?
Aperture is still fixed, but there's also a mechanical shutter but this is good for photografy. Still a problem with video. You can't use too fast shutter for video capture.
Correct, the new aperture control in P4P is a huge step for drones. This will likely forgo the need for ND filters in most cases.
Oh waw I got it now on the camera specs ... Interesting really!!
jeetbuzz360
