Is the P3 Standard's GPS normally this prone to loosing satellite lock at ground level? Here's a couple examples I've experienced:
After having landed in an open field, I can walk over my aircraft and as I reach down to turn off the battery, I can hear my Go app say "Atti mode" and when I look down at the screen there's 7 satellites indicated. When I move my hand away from the aircraft, it cleverly goes back into P-GPS mode while still showing 7 satellites. Once in the air there's no problems with the aircraft inadvertently switching flight modes.
At times before taking off, the GO app will indicate 6 satellites acquired but even after waiting 3 more minutes will not have switched into P-GPS mode. Power cycling the app, remote and aircraft usually corrects this issue.
I never had this problem when I flew using the latest Android GO app on my tablet or the previous iOS GO app in conjunction with 1.8.10 firmware.
After I had updated the iOS GO app on my iPhone 6S-Plus to 3.1.15 and the firmware to 1.9.20 the issue first appeared. Reinstalled the app from the App Store and it made no difference. Once in the air, the aircraft flies just as well as it before the upgrades.
I don't know if the upgrades are to blame or should I go shopping for a new GPS module.
