P3S - DBS mod - M.Power 5 - Bad FPV !
Greetings from Greece !
One year with my P3S, and this summer I enjoyed it ,at my vacations.
Maximum RTH range with no loss FPV , was with, (argtek & MPv5 ) ~700 meters.
But...
When I returned home ,i tested and the problems started ...
FPV feed gone 100% to 0% at about 40-50 distance-altitude !
I know a lot of 2.4 G ,wi-fis in my area...
SO I decided to buy the DBS mod,i installed on the argtek base ,easy and test it again...the results ? see :
Airdata UAV - Flight Data Analysis for Drones
I lost only FPV,but i afraid to continue,because of the bad enviroment with a lot of houses...
This weekend, I tried to test it at a more open space ,check the results (same story,100% fpv and suddenly gone to 0% ):
Now the final test (before to call it a hardware malfunction...) is to get to a seaside (with no wi-fi's around) to try to check what can make as FPV range ...
Any Ideas ,Help !
i'm having issues with distance I was able to fly out to 7k with the DBS flew today got to 1500 ft and disconnected tried 3 more times same issue. I am wondering if everything going on right now in the US with storms and all the violence in cities has something to do with it. Im sure the air is full of radio waves and other transmission from communication systems its the only explanation I can come up with
