P3P fw downgrade txt file
Hi I've just downgraded my P3 does this txt look ok?
Thanks
Ste
Result: Success.
========== 2015.12.04 13:39:40 =====================
Packet: P3X_FW_V01.05.0030.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.12.04 13:40:16 =====================
Result: Abort.
========== 2014.01.01 00:00:13 remo-con disconnect======
Upgrading ...
Result: Success.
========== 2015.12.16 16:39:43 =====================
Result: Abort.
========== 2015.12.16 16:44:02 =====================
Result: Abort.
========== 2015.12.16 16:47:30 =====================
Result: Abort.
Result: Abort.
========== 2015.12.27 14:21:40 =====================
Result: Abort.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
It shows the downgrade was successful. Do you see version 1.4 in the "About" section of DJI GO?
It looks you successfully downgraded to 1.4
Why do you get date stamp of 2014?
