P3p firmware update text
Does anyone know what this text file means. Currently the bird is only making the loud beep constantly. No lights on the body. Gimbel led does change red and green then too green flashing and starts all over. Stuck can't go forward or backswards in firmware. I get spotty video from cam. Gimbal works. No info from the bird.
Delete history success.
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3X_FW_V01.06.0040.bin
========== 2014.01.01 00:00:13 remo-con disconnect======
========== 2014.01.01 00:00:12 remo-con disconnect======
It is bricked. Just loud alarm clock beeping and no lights on the craft. Gimbal lights flash red and green then flash green and back to red and green again.
Red and green is a good sign. Let it continue. Ignore all other lights on the craft.
Trying over 1 hour no change. Controller doesn't get info from bird but i can from camera. I did notice the 8pin wire was skinned up in the bird.
Well, that could cause an issue. It sounds like you need to reconnect it properly and/or replace it.
Check the wire on the gimbal that comes out from body. Sometimes it does not connect properly. İt happend to me like you. İ dont remember the light color combination but i saw that the wire on gimbal disconnected.
Just went thru and replaced all the cables. I think its bad ribbon or camera has a problem. It is the only thing that need updated.
