P3A - how to bbtain location, height + gimble angle?
Herefordshire
I've searched but can't find an answer - this may apply to others (not just the P3A)
When you're flying you can see the GPS coordinates, and also height but where you can see the gimble angle (an actual deg value, not the slider graphic)?
Otherwise, is it possible to take a photo (or make a waypoint) and then get the info from Exif, or similar?
TIA
Adam
In Litchi you can specify GPS points and the gimbal angle in negative degrees, you can save those waypoints for later use.
There is no direct way to get the camera angle but you can definitely set poi s in missions and set the cam to look at them. That way you can set a calculated angle. Try Litchi for setting such missions
Thanks. I know litchi so I'll go that route. I was hoping to form a litchi mission from a sequence of existing P3A images.
I was just wondering if I was missing something obvious!
A
If you know Litchi missions then you are good to go.
You can get the gimbal angle from your flight log.
