P3a ce range
doesn't matter if its usa model if your flying in uk it automatically goes into ce mode
Yup, that's what I meant just to clarify.
Reactions: flpholt
yeah if it was different we could make a mint on shipping over usa ones oh well to bad
Hi. I'm in the UK. I recently bottled out at 2 miles and brought it back with no signal issues experienced. Stock out of the box.
Wow that range is awesome. Did you fly it without much interference? Or was it in a fairly built up area?
I'm in the UK and get 2'500m stock in a very congested (wifi noisy) location.
Never had less than 2000m anywhere, that's a long way line of sight!
Reactions: Reed L
2800-3000m in CE (europe), but with simple homemade windsurfers up to 5400m.
Well this guy did over 6KM with the P3P in Germany (definitely in CE mode).
And this other guy did over 7K with the P3P in Turkey.
All depends on signal and noise, since the CE laws have lower radio output on devices, means there may also be less noise as well (and not traveling as far) so for things like the Phantom this can be even better in built up areas since things like routers inside have a lower range penetrating walls
In EU have had 4.5km out and back no issues, fully stock setup. Probably would have gone more.
Reactions: Reed L
So even in CE mode the P3A can fly a long distance. It seems such a good drone but is pricey.
They are all the same it uses the GPS to establish where it is then adjusts the power outputs to suit location :)
Yep, as others have said the P3P and P3A are the same machine with the exception that the P3P has a better image processor board and can do 4K and 10mb/s downlink where the P3A can only do 2.7K and 2mb/s downlink. Both use the same lightbridge hardware which seems to be better then the updated P4. FCC an CE mode just varies the channels and output depending on location. The one different unit is the Japan version which uses 900mhz frequency instead. The lightbridge on the P3P/A line is why they are such a good deal. The P3S doesn't have this and the P3-4K seems to have a more crippled version of Lightbridge.
P3A here in Sweden (unmodified CE equipment).
1,5 km is no problems, 2 km will require decent conditions, 3 km is definitely pushing the envelope.
My max distance is 3 km in a rural area at 200 meters and with clear line of sight (although with several power lines and cell phone masts below). I started to lose the video feed at 2.7 km (red warnings and rapidly increasing bursts of video glitches and dropouts).
//Tom
In open field in EU I went 1700 m without any problem, having full signal and then came back. So you definitely wont have any problem regarding CE distance. I was asking myself the same question before purchase.
Thanks for the info. I am just wanting to know everything before I purchase the P3A
Buy it and dont look back :) Only if you need better FPV quality on the phone/tablet buy Professional, it has 10 mbit vs 2 mbit on Advanced. But it also looks perfect on Advanced. 4K video is overkill for now.
I think that is exactly what I am going to do ;)
Do you any places to get a cheap P3A? The cheapest I have found is £580.
£545 from here, I can't vouch for the company though, so your choice!
A complete 2.7K camera and 3-axis gimbal system come integrated with the Phantom 3 Advanced edition quadcopter from DJI. In addition to video, the camera is capable shooting up to 12 MP still photos using JPEG or non-proprietary DNG RAW format. The three axes of the gimbal give you pan and tilt control, and keep the horizon line level even as the aircraft banks. Different gimbal settings allow the camera to lock onto a fixed subject, be moved manually using transmitter rotaries or the app, or to simply provide camera stabilization. This bundle of the Phantom 3 is classed as "ready-to-fly." This means the basics to get you in the air are included - a flight battery, charger, and pre-bound handheld transmitter (radio controller), and 16GB microSD card among them. Depending on your application, you may also require additional memory cards, additional flight batteries, and a mobile device to access the app, and possibly other accessories. Also note that a number of important compass and GPS calibration steps must be carried out before flying to ensure the flight control computer operates correctly. Please refer to the manual or Quick Start Guide before your first flight. Phantom 3 Flight Control System Main Controller The burden of processing and analyzing flight data in real time it taken up by the Main Controller, the brains of the computerized flight control system. It collects data from the entire system, including motor speed, GPS location, your command inputs, and data from automatic sensors, and analyzes it all to tell your Phantom 3 exactly how to behave at any given moment GPS Navigation Because of the complexity associated with multi-rotor aircraft the Phantom 3 relies on a GPS-based navigation system to maintain flight stability and provide other features. While fully manual operation is possible, most users, especially videographers hoping to get the smoothest possible shoots, will opt for one of the GPS-assisted modes IMU The Inertial Measurement Unit (IMU) uses a 6-axis gyroscope plus an accelerometer to keep track the slightest tilt or change in acceleration. This data is relayed to the Main Controller and used to help maintain a stable flight ESCs Four Electronic Speed Controllers (ESCs) not only relay vital motor speed information to the Main Controller, they also send commands back to the motors based on your input. This constant communication helps keeps your Phantom 3 stable in flight, and also helps you achieve any flight movement, from gentle pans to rapid acceleration Vision Positioning System for Indoor Navigation Vision Positioning System uses a specially designed camera as well as sonic waves to provide comparable stability function indoors or close to the ground as GPS does outdoors. This technology allows the Phantom 3 to hold its location, stop when the controls are released, and quickly respond to pilot commands even when GPS is unavailable Auto-Takeoff With one tap in the DJI Pilot app, the Phantom 3 will turn on its motors and raise to a pre-set height. It will then hover in place, completely motionless until you direct it where to go Auto-Landing When GPS is available, the Phantom 3 remembers the exact spot that it took off from. Simply tap a button to have it return to the point from which it took off Return to Home Failsafe If the Quadcopter loses the signal from the controller for any reason or the battery starts to run low the "return to home" feature will initialize. The aircraft will ascend to 60 feet then make a straight-line course back to the "home position" you will have defined during the GPS calibration process. Once there, it will safely descend to the ground and power itself off Intelligent Orientation Control (IOC) IOC is designed to help make flying more intuitive. Nominally, the yaw control will allow the Quadcopter to rotate continuously, which can quickly become confusing if you lose track of which way is "front". Suddenly your controls can get mixed up, where pressing right causes the craft to move left and pressing forward causes it move backward. Intelligent Orientation Control prevents this from happening, keeping the "tail" of the Quadcopter pointed roughly toward the pilot at all times On-Board 2.7K Camera Up to 2.7K Video and 12MP Stills The included camera system features video recording at up to 2.7K30 (2704 x1520) in H.264 and also takes JPEG and DNG RAW photos at 12MP. The camera mounts via an integrated 3-axis gimbal that provides stabilization as well as pan and tilt control. Media is recorded internally to a microSD card Video Resolutions and Frame Rates 2.7K (2704 x1520): 30p, 25p, 24p 1080p (1920 x 1080): 24p, 25p, 30p, 48p, 50p, 60p 720p (1280 x 720): 24p, 25p, 30p, 48p, 50p, 60p 94° Wide Angle Lens The camera features a 94° angle-of-view lens, which is a narrower angle than a fisheye for less distortion while still being wide enough to enable capturing establishing shots. The lens features an f/2.8 aperture and is comprised of 9 elements, including an aspherical element Integrated 3-Axis Gimbal The gimbal provides stability by counteracting unwanted motion such as wind buffeting or vibration and also keeps the horizon level even as the quadcopter banks. Control dials on the transmitter (radio controller) allow you to manually pan and tilt the camera DJI Pilot App for Android and iOS Camera Control and Live 720p Monitoring View a live 720p HD image with the free Pilot mobile for Android or iOS mobile device. The app also enables full camera control, letting you set parameters such as camera tilt, ISO, shutter speed, white balance as well as set video start/stop and take photos. The mobile device tethers to the transmitter via USB (cable available separately). A wireless range of up to 3.1 miles line-of-sight is provided (depending on conditions) In-App Editing and Upload Once recorded, photos and video footage can be downloaded directly to the phone allowing them to be edited complete video with music, text, and more, and shared on Facebook, Instagram, or other social media networks - even while the Quadcopter is still in the air. If you have an Internet connection, you can even stream live to YouTube Flight Simulator The app isn't just for flying. A flight simulator allows you to get some practice in before taking to the skies. A flight log allows you to review all of your past flights, with the time, duration, and even photos and videos you took Handheld Transmitter (Radio Controller) Included Intuitive Design With sensitive control sticks, dedicated buttons, and over 3.1 mile range, the customizable Phantom 3 remote controller has been designed to put the controls you need where you need them. Functionality includes: Power on/off Take photos Start/stop recording video Gimbal control dial Camera settings dial Sensitive control sticks Flight mode switch Return Home button USB output Customizable buttons Mobile device holder Power indicators Slip-free rubber matte Integrated Lightbridge Ground Station Support Control, a live video feed (FPV), telemetry overlay (OSD), and more are all rolled into one app-based solution. Simply mount a compatible iOS or Android mobile device (available separately) on the transmitter (controller) with the included mobile device holder and connects via USB. Communication between the app and the Phantom 3 is facilitated by the transmitter's radio, meaning signal quality won't be hampered by relying on the mobile device's Wi-Fi Mobile Device-Compatible A type A female USB connector is provided for tethering an iOS or Android smartphone or tablet for live FPV monitoring and camera operation. A mobile device holder is included for mounting your device directly to the transmitter. It adjusts to accommodate both smartphones and tablets in landscape orientation Rechargeable Battery A 6000mAh LiPo battery is provided to power the transmitter. An AC charger is included for charging the battery while in the transmitter. Four LEDs on the front of the transmitter indicate remaining battery life or charge status Additional Features Intelligent Flight Battery The flight battery slots into the "tail" of the Phantom 3 and features and on/off switch plus four LED charge indicators that are visible while flying - so you can keep track of remaining flight time without needing to consult the app. For recharging, balance and power regulation is handled internally within the battery itself. You simply plug it into a wall outlet with the supplied power cord and you are good to go Self-Tightening Rotors Computational fluid dynamics (CFD) have been applied to the prop design, providing them with increased thrust and better efficiency compared to previous props used on earlier Phantom models. The self-tightening design helps ensure they do not loosen in flight and not require a separate prop nut UPC: 190021000001
rockymountaincaptures
