P3 PARTS
I have a P3 4K drone and the module behind the camera lens has a bad connector where the ribbon cable goes. Some very small contacts came out while changing the ribbon cable. I know the Pro/Adv 4k camera entire units won't fit the P3 4k but I think the board behind the lens should be the same board. I will take one if you have it. I need this drone operating again. How do we get in contact?
i need a roll motor P3S
could use a few other parts too. please respond
see parts circled in photos below
I need the whole camera *** for my p3s from the bottem of the drone down it had a meeting with a tree i guess it's called the gimble, can you help and how much
I'm looking for a P3S circuit board - the one just above the yaw control motor. Mine is missing the 2nd set of contact pins from the right. I still have the pin - I just don't have the skill or the equipment to solder it back onto the board.
I am looking for a P3S gimbal pivot (roll) arm with motor attached. Do you by chance have one of those?
Arcadia JC
