P1 Gimbal pitch Fails when Copter is powered on
I believe it is the original Phantom....after some more testing I discovered the gimbal works fine, IF I do not connect the manual 4th channel
pitch control.
Reactions: rattydude77
pitch control.
If you have the 1.1.1 you should have a lever on the back of the controller go into the firmware to see what the pitch is set to if you have the 330 model phantom 1 it won't have the lever on the back.....
hcashmore11
