Manual pitch control on gimbal not working.
Discussion in 'Phantom 1 Discussion' started by PJ105, Jul 27, 2014.
  1. PJ105
    So I installed my 2-axis eBay gimbal ( http://www.ebay.com/itm/331078385980 ) and followed all the instructions. The gimbal powers up and works perfectly. However, the manual gimbal pitch does not work (I have a V1.1.1 with the handle in the back). I can see the X-1 channel indicator moving, when I move the lever, but the gimbal pitch remains level. I know these gimbals are not the best, but is there something that I may be missing? I connected the signal and ground pins properly to the F2, and left the white one unconnected (I think that's the 5v). I'm waiting to hear from the seller, but is there some solution to this? Thx in advance.
  2. Gizmo3000
    Sherman Oaks, CA
    you did turn the gimbal control on in the NAZA assistant right? (and set the proper settings in the NAZA) and connected the gimbal pitch to F2?
  3. PJ105
    Yes, forgot to mention that. Gimbal function to "on" and the gains to 85%. Anything else i missed? I also calibrated the lever. And i used the F2 connection, which was the first one from the left. Maybe its mismarked?
  4. PJ105
    There was also a drop dowm menu for frequencies....I used 400hz.
Similar Threads - Manual pitch control Forum Date
Manual pitch control reversed! Phantom 2 Help Jan 8, 2016
Camera manual pitch control lever, whats the fuss about ? Phantom 2 Vision + Discussion Oct 31, 2014
Arris CM2000 Manual Pitch range limited General Discussion Oct 19, 2013
phantom fc40 manual Phantom FC40 Help Aug 6, 2017
Guinness Book of World Records for most drones flown manually in one area Photos and Video Jul 8, 2017
