One motor damaged or more
wow that is strong ! And your way might have worked. In the end I did this
So I can go ahead and order a single esc now many thanks.
So I see there is a v2.1 mine is a v2 so need to source the same I'm guessing.
No the v2.1 will work in both models of the P2 non-vision. Besides it is highly unlikely that you even find a v2.0 ESC module
Thanks appreciate all your help on this one - I will go ahead and get that ordered :)
Glad to see you got those two screws out. But you should fill those cuts in the body from the dremel with some two part epoxy as that area is prone to cracking.
