Official P3 Range Leaderboard
I couldn't tell you for sure. That's beyond my understanding. When using boosters and only a few feet away the video gets choppy. Mine will say poor quality the whole way out but I don't have any problems. Video and control work just fine. It's a little misleading haha
Can you overnight me 2 more sunhans and charge my card. And I will send back the 2 that I got today and you can credit me when you get them. I'm leaving on Saturday on vacation and needed to get this working as I am meeting other p3 groups to do some tests and long distance flights.
PM me your order number
Reactions: Zuzua
Great!!! did you use 5.8G anntenna also?
Of course, (2) 2.4 19dB - (1) 5.8 19dB panel Boosted
Reactions: Lee SK
Been trying to troubleshoot my boosted maxx panel. It does increase range, but not as much as I thought it would and the video is choppy when boosted. Changed out all cables and swapped the two amps.
In all fairness I have to say that flying from the back of my house it's far far far from los! Trees right in front of me and then houses then it opens up. From the front of my house I have very good los and open field, in this direction the battery is the weak link in the chain, unboosted I've gone out 21500' with solid video and radio signal but boosted the video is choppy and lags a lot. So at this point, even though the range increase does work some what, the video is not up to par! I've asked Jake for another set of amps and cables to rule out hardware.
I'll attach photos as they speak clearer than words.
Great set up DB. Zuzua you are not going far in the back yard, no mater that you do. Well you could cut the trees down. :rolleyes:
Please check your signal score^^
Please find a good place for best signal score(I found that signal score of DB : 100)
Well, the whole reason I got the boosters is for penetration in places that stock signal would not be sufficient. In open spaces and good los stock RC outlast the battery.
From the front of my house where I got my record of 21500' out I was using maxx panel unboosted signal strength 74. I will do the same path in a minute and let you know what it is there, but I'm pretty sure it will be around 100 boosted but the video signal and quality is worse than unboosted.
Reactions: dirtybum
mumbaiescortshub.net
