- Joined
- Oct 3, 2015
- Messages
- 153
- Reaction score
- 86
- Age
- 37
Under the VPS amazing battery life landing with 32.10 minutes still had 20% battery life.How tied multistar 5200mah lihv with UVA?
Did you use zip cable ties also?Under the VPS amazing battery life landing with 32.10 minutes still had 20% battery life.
Can I connect Multistar 5200 LiHV in parallel with Dji lipo. I have battery mode with two cables soldered to the main PCB.Under the VPS amazing battery life landing with 32.10 minutes still had 20% battery life.
I think that that's OK!Can I connect Multistar 5200 LiHV in parallel with Dji lipo. I have battery mode with two cables soldered to the main PCB.
Zip ties and some strong Velco heavy duty self adhesive stick. VELCRO® strong Velcro Heavy Duty Self Adhesive Stick on Tape 50mm wide BlackDid you use zip cable ties also?
i'd be careful strappin them down there like that pro, might mess with the compass and your signal strength, try some of that good tape you have and do it like thisZip ties work great..huge shout out to DB for helping me out!!
This happens because your external battery has a little more juice than your main battery so it tries to charge your main battery. To solve this problem, wait for the ready to fly GPS signal before you plug the external in and then as soon as you plug the external and take off and hover, when you take off and hover quickly the main bat usually stops blinkingSometime I found a battery error message at DJI GO and DJI main lipo was turn off just as soon as take off.
Please let me know that what is a primary cause?
Bummer man!!! You'll get 'er next time!@JakeMaxxUAV
This was intended to be a round tripper but storm front came in and winds shifted on me!
Suicide Mission - 55,075ft
P3A - Maxxrange, Boosted, Battery Mod.
Ha,haaa! Welcome to the club DennyBoBenny!!! You're one of us now! Don't worry man,it gets easier! Sometimes just got to give that bird a little freedom she'll[emoji41] come home when she's ready, or when you're ready to go get her that is@JakeMaxxUAV
Beat my previous record of 20,232 feet...this one is 23,378. P3A with small ItElite panel unboosted, stock bird and battery. As you can see in the picture, I was a mile short of making it back. I hadn't really planned on making a distance run, so I was messing around at the beginning of the flight, otherwise I would have made it back. I don't know if this qualifies as a suicide run, a return run, or neither. That's the first time I haven't made it back home and it was a little scary. Man, when that thing wants to auto-land it starts dropping in a hurry! I was able to keep it in the air until I set it down in some tall grass next to the road a mile away, jumped in my car and drove there fast to retrieve it. She was just sitting there patiently waiting for me. I had control of it all the way down, even a mile away...amazing!
You did Great!!! Did find your P3?@JakeMaxxUAV
**** man you went after it huh? That would have been tough to beat bro! Your battery life is pretty good man you should get 10 plus all day long!!! That took balls man hell of a run.@JakeMaxxUAV
