No video feed after crash.
I crashed and no video feed. I get iOSD info but no video from gopro. GoPro works fine.
The ribbon cable from inside phantom to the gimbal/FPV Hub looks damaged. Could this be my issue and is it easy to replace?
with out being able to take a closer look, it looks like to one cable from the gimbal in your photo has one lead that's punctured completely through. I'd say replacing that cable would be a real good place to start.
if you noticed that's the ribbon cable that goes directly from inside the P2 to the gimbal... is that hard to replace ?
ianwood said:
That cable is damaged and needs to be replaced or repaired.
It carries the video to the hub/phantom/tx?
Is it just a plug in type or do i need to solder... does anyone know where i can get the part?
mikeyduhaime
