- Joined
- Jul 1, 2017
- Messages
- 16
- Reaction score
- 1
- Age
- 84
map on lower right corner no longer shows anything but gray screen. If i review flight from flight records map of flight is there. do not know what has gone wrong any suggestions?
using i pad mini but would like to reinstall 3.1.13 appWhat device are you using the app on?
I'm on a iPad.... which, when you hold down on the icon it starts shaking and an "x" appears on the corner. You push on the x and it asks if you wish to delete. Click yes and then download from App Store.
Not sure how to do it if your not using DJI app.
how do you delete go app and can i reinstall the old app i was using?
I deleted mine but and reinstall and no luck...don't know what else to do.Happened to me too! Tried everything and no luck. I Deleted the Go app and reinstalled and everything worked perfect. Hope this helps.
had this happen after it worked well for several flights (i pad mini) got notice about cpu could not process and found several programs running in background, this eats up resources quickly. cleared background and maps were back hope this helps.I deleted mine but and reinstall and no luck...don't know what else to do.
