Your Tx on the gimbal burned out.
Remember all, when updating firmware on P3, particularly on P3P to use a house can and point it to the P3 at full speed to blow in The general direction of the gimbal while upgrading so it has air flow. Otherwise you might overheat the gimbal and Tx will burn out causing what rotary sees on the screen above.
