Hi, New P3 standard with no satellite signal at all... open area, s1 switch up, Galaxy s4 but tried with newer Iphone and the same, no GPS signal... tried reinstalling djigo app again, still the same.. any ideas?? Thanks in advance
Hi, yes.... activated, uploaded firmware, calibrated compass and sensors. Flew it GPS-less for a minute to see if that worked but nothing.. actually took a small aerial vid but got real confused with controllers and landed successfully manually. Any help is appreciated..thank youSo just to start off, you have the controller connected to the drone via wifi correct? Have you calibrated the compass? Linked the remote to the drone? Just simple things to get out of the way
Go into your DJI go app settings and see if your GPS is reading zero or if there are numbers associated with itHi, yes.... activated, uploaded firmware, calibrated compass and sensors. Flew it GPS-less for a minute to see if that worked but nothing.. actually took a small aerial vid but got real confused with controllers and landed successfully manually. Any help is appreciated..thank you
Yes!!!!! Telling me flying in Atti mode , even when switch is up.... and I enabled switch function in app too... hmmmmm. I'm stumped.@Araya38
He was a couple other posts here.
**Green horn alert**
@CygnusX1
Is this a brand new unit?
So you got all other data (Telemetry) on the app?
Is it telling you your flying in Atti mode?
Rod
Hmmm...so on the app itself, its showing that no satellites are connected at all?Yes!!!!! Telling me flying in Atti mode , even when switch is up.... and I enabled switch function in app too... hmmmmm. I'm stumped.
GPS module is on Aircraft and not on phone, or tablet. You need to get your drone replaced/ repaired. Don't fly in ATTI mode as thats too risky for a beginner.Hi, New P3 standard with no satellite signal at all... open area, s1 switch up, Galaxy s4 but tried with newer Iphone and the same, no GPS signal... tried reinstalling djigo app again, still the same.. any ideas?? Thanks in advance
I'm thinkin the same... probably cheaper to replace it myself than to ship it back across the country.. saw a new module for 85.00.... thanks for your time and help
Hi.....yep, all boxed up and ready to go back... Thanks all, I really appreciate it... lol @ Fly by Night!!!Yeah, we are all trying to figure out that is something your not telling us (explaining), or not doing correctly.
Through these post, I think we all agree that your unit is defective. If you can find something simple like a cable unhooked, that's great.
But if you start replacing parts?
Your in the states, if you can't get it replaced, last time I sent something in to DJI, California, they sent me the shipping label, I had no shipping charges ether way.
Maybe it can "Fly By Night".
Rod
