No any devices found during firmware resintallation
NPR
I have several issues on my bird, no any crash, just happen suddenly
Then unsuccessfully tried to reinstall firmware with micro sd card dozens times but after check log file
I noticed that firmware re-installation got frozen right before version checking:
[00010184]========== Upgrade: remo-con disconnect. boot(1424)============
[00010203]Packet [C:\P3C_FW_V01.09.0200.bin] detected, card sn [0x000004db].
[00010214]Packet upgrade start...
[00010231]Packet checking...
[00010252]Packet vlink 01.09.0200 <-> 00.00.0000.
[00010263]Record vlink 01.09.0200 <-> 00.00.0000 (flow = 0).
[00010273]Done.
[00010284]Version checking[1]...
[00010273]Done.
I tried hard several ways to re-install firmware but always same issue.
Appreciated any help, thanks.
[00010273]Done.
[00010273]Done.
If I saw "00.00.0000" in my log, I would assume an issue during the update process and the currently installed FW could not be determined. The first thing I would check would be that the cables connected to the gimbal / camera were well seated. I might even disconnect them and then reseat them just to be sure. Then I would try again to see if that helped.
Appreciated your answer, in fact, I re-installed checked the ribbon cable but did not fix the issue, I was thinking that if the sd card it's being read and written then the problem of not recognize the firmware nor devices should be somewhere else, don't know exactly where.
most
