New troubles after DBS Mod
I got my dbs installed in the wee hours of the night last night and went for some test flights today. The range truly is outstanding.....until......"Connection Lost!". I wait patiently for RTH to kick in and nothing. I take a few deep breaths and move the rc all around until I find a signal. I hit RTH and all is good. I've done this twice today. Tonight, I pull the card from the camera and I find that the video stopped recording at the same time that I lost connection and restarted a new video once connection was restored. This has me VERY concerned. Opened up the rc and all connections are good and very solid. It would seem that I fly past the point of no return with no warning. Not sure what would happen if rth did not kick in and I could not reconnect.
sounds like your wifi connection was lost which the video link uses, not your RC connection if RTH signal reached it.
which means you should still be able to control the craft even if you can't see it.
Why did the AC video stop and restart? Also the flight log shows numerous Mode Changed to GPS Atti numerous times? Do I have a controller issue?
Flight time Altitude Home Distance Type Notification
A 00m 00s 0.0 ft 0 ft Mode Mode changed to GPS_Atti
B 00m 00s 0.0 ft 0 ft Tip Home Point Recorded
C 00m 02s -1.3 ft 0 ft Mode Mode changed to Assisted_Takeoff
D 00m 02s -1.3 ft 0 ft Warning Return-to-Home Altitude:147FT
E 00m 16s -2.0 ft 0 ft Mode Mode changed to GPS_Atti
F 02m 57s 348.4 ft 2,348 ft Data Loss Downlink data connection lost for 11.1 seconds
G 02m 58s 348.7 ft 2,348 ft Mode Mode changed to Go_Home
H 02m 58s 348.4 ft 2,348 ft Tip Returning Home
I 03m 03s 348.1 ft 2,328 ft Data Loss Downlink data connection lost for 1 seconds
J 03m 44s 348.4 ft 1,090 ft Mode Mode changed to GPS_Atti
K 07m 01s 368.1 ft 4,217 ft Data Loss Downlink data connection lost for 7.3 seconds
L 07m 01s 368.1 ft 4,217 ft Mode Mode changed to WiFi_Reconnect
M 07m 01s 368.1 ft 4,216 ft Warning Signal Lost. Aircraft Returning Home
N 07m 03s 368.4 ft 4,216 ft Mode Mode changed to Go_Home
O 07m 07s 369.4 ft 4,180 ft Data Loss Downlink data connection lost for 1.2 seconds
P 07m 08s 369.4 ft 4,143 ft Mode Mode changed to GPS_Atti
Q 07m 10s 369.7 ft 4,102 ft Data Loss Downlink data connection lost for 1.2 seconds
R 07m 12s 370.1 ft 4,098 ft Data Loss Downlink data connection lost for 1.2 seconds
S 07m 43s 368.4 ft 4,156 ft Data Loss Downlink data connection lost for 1.4 seconds
T 07m 45s 368.8 ft 4,173 ft Data Loss Downlink data connection lost for 1.5 seconds
U 07m 48s 369.1 ft 4,213 ft Data Loss Downlink data connection lost for 1.4 seconds
V 07m 51s 369.1 ft 4,238 ft Data Loss Downlink data connection lost for 1.7 seconds
W 08m 23s 398.3 ft 4,327 ft Data Loss Downlink data connection lost for 16.9 seconds
X 08m 24s 398.3 ft 4,327 ft Tip Returning Home
Y 08m 24s 398.3 ft 4,327 ft Mode Mode changed to Go_Home
Z 08m 38s 398.9 ft 4,052 ft Data Loss Downlink data connection lost for 8.7 seconds
a 08m 38s 398.9 ft 4,052 ft Tip Returning Home
b 09m 51s 397.6 ft 1,728 ft Mode Mode changed to GPS_Atti
c 13m 40s 397.3 ft 3,702 ft Data Loss Downlink data connection lost for 1.2 seconds
d 13m 55s 399.6 ft 3,804 ft Data Loss Downlink data connection lost for 1 seconds
e 14m 00s 398.0 ft 3,806 ft Warning Return-to-Home Failed
f 14m 07s 397.6 ft 3,806 ft Data Loss Downlink data connection lost for 6.3 seconds
g 14m 08s 397.3 ft 3,806 ft Tip Returning Home
h 14m 08s 397.3 ft 3,806 ft Mode Mode changed to Go_Home
i 14m 39s 395.7 ft 2,903 ft Data Loss Downlink data connection lost for 15 seconds
j 14m 39s 395.7 ft 2,903 ft Tip Returning Home
k 16m 08s 324.5 ft 9 ft Mode Mode changed to GPS_Atti
Just opened it back up and tripple checked the connections. All looks good. I wouldn't have suspected an antenna issue. I'm getting considerably more range in this urban area than I have ever gotten before. What makes it switch to atti mode besides the switch? Nice clear night. Now, I am flying over areas that I previously could not reach. Possible interference?
loss of satellites signal makes it drop out to atti mode.
Reactions: Matts175
Ok, what would make the ac video stop recording and restart? The only thing I have not done.......and should have, was to restart my phone pre-flight. Just thinking that may be the problem.
Yup. A ton of apps running in the background can cause all kinds of problems. That's why I bought a tablet that ONLY gets used for my P3. Don't want Mom calling to talk about her cat when you're right in the middle of a 12,000 foot distance run.
peoplelogic
