You need to take your charging cable and plug the big end into the back of your remote controller and the little end into your phone. Then open DJI Go app and it should connect.After I got my new phone I can not get To Go off How to Connect and on the camera. I have tried reinstalling it. It does have a pop up about Inspire 1. My new phone is a Moto z3
I have a P3P and its the remote that came with it.What model drone and remote do you have.?
I have all the cables attached and I'm using the same cable I use with my tablet. I was just going to use my phone because my tablet had died.What Wes said. Most times an "unable to connect" is caused by a cheap cable
Not sure and I don't have it with me right now. It works with my old phone and tablet but not my new one.Couple of different remotes for the P3P. Is yours a 300C?
I have done all that and it still does not work.You need to take your charging cable and plug the big end into the back of your remote controller and the little end into your phone. Then open DJI Go app and it should connect.
For better video signal you will want to buy a better USB-C cable that is rated for high speed data transfer. I suggest the Anker Power line cables.
I haven’t looked, but is your phone on the list of compatible devices.?
I guess I don't know. Where do I find the list.
One relatively common issue with new Android devices in the past has been that their usb connection is sometimes set as charge only.My new phone is a Moto z3
That is a very common problem with Androids - I had this issue with my Nvidia Shield, you have to activate the Developer Mode" and yes, follow these instructions to the letter!Try this. I had to follow these procedures to get a new Samsung tablet to work with DJI Go and my P3P ‘s
