New here, looking for help P4 battery sensor
Hi everyone, new around here
Been reading everywhere and only place I find it mentioned was this forum. I bought a 2nd hand P4 couple of years ago only issue is the battery sensor which has made almost not use it cauz everytime is a prayer to remove the message, so I barely use it. Im wondering if there is a way to either bypass that circuit or fix it (like opening the drone and cleaning or readjusting the clip)
Reactions: RodPad and GFields
Could you share the exact message you're seeing?
Also, when does the message appear and where do you see it?
Reactions: RodPad
Greetings from Birmingham Alabama USA: welcome to the forum! We look forward to hearing from you!
Reactions: RodPad
From what Ive read is the typical message from the P4 V2 battery sensor, saying battery is not properly in place. Message shows as soon as dron is turned on. Attached images of the error and also of the culprit which is the sensor only present on V2 P4
hcashmore11
