Question on waypoints. Can you save them for later? As in, can I fly & save a route today and it will be available for me to use tomorrow?
At the risk of starting a war, I would like someone to explain - with actual factual info - why an IMU calibration is "necessary" if the system tells you it isn't, and all of the sensor values are the same as they were before the firmware upgrade? I'm trying to pick a scab, but so often "conventional wisdom" is grounded more in custom than in fact.
After, or possibly during, you record you mission there is a star in the top right corner of the planning window. That is the FAVORITE button of sorts. His that and it will be saved for future use. I'm not sure where the data is actually saved though. In the P3? In the Controller? Or in the app?I heard something about "favorite route". Idk
I mentioned several days ago that most would be disappointed in waypoints. 500 meters is nuts!!Waypoints are useless. 500M distance limit from homepoint. That wont even cover a farm field. FAIL but at least Litchi still works fine.
You can never exceed 500m altitude, in any mode. The limitation is 500m from the home point.500m as in the height limit or a new waypoint 500m limit that never existed before?
There is no documented reason. The only time a IMU calibration should really be required after an update is if the past IMU cal. data is wiped during the update. Which would lead to a warning that the IMU needs calibrated. Unfortunately, that doesn't work with logic. As we have seen in several instances, a compass calibration WAS needed, even though there was no warning of its need, and there was no indication by observing the compass MOD value.
In the end, documented or not, those ritualistic calibration activities obviously CAN have some value.
So you can, for example, set a 2 point mission to fly from 500 meters away from the home point at 3m altitude to a waypoint 1km away, at 500m altitude500m as in the height limit or a new waypoint 500m limit that never existed before?
You can click the little star icon to favorite a route.I heard something about "favorite route". Idk
A sample of poi and 2.7
Does anyone know what software versions should be displayed in the GO App after the latest firmware update has been completed?Well only a few hours to go.
Looking forward to installing.
Flight POI and 2.7k for my advanced.
