Why? You can downgrade to 1.4? How? This method like Les Grossman said?
Thanks , will give it ago nowDownloaded the bin file here DJI Phantom Accessories & Tips - Phantom Help took a blank microSD and copied it on the root folder. Then turned on the aircraft without SD, Turned on remote and connected smartphone with DJI as usual, then inserted the SD in the camera. The installation automatically starts, wait for a while, that's it! (anyway attention to firmware changes, they could brick the Phantom...)
No luck here...
I tried 3 times.
When i hold sync button, the 1.6.8 "upgrade" show up, click on it, and that's write fail... i restart everything, seems ok, because, it1s write i have 1.6.8. on dji go.
than i put 1.5.7 on sd, restart everything, with hold sync. Dji go writes the same, the 1.6.8 "upgrade" shuw up, i need to upgrade to 1.6.8. Ok i stay waiting about 30 minutes, but nothing happen.
What do i wrong?
I need to be see "updating" word when it's ok? or different sound or anything?
thx
Cheers , think I`ve done it but I also pressed the link button on the side as I started the P3S . I have the red banner now saying a new firmware update available 1.6.80 so it must of downgradedNow I read once again the method, and I forget something: Before every attempt FORMAT the memory card in a PC. Because DJI writes hidden files to the sd card. You can see them, if you switch the folder settings in the windows.
Thx,
I will give it a try! By the way, because i can't downgrade, i reload 1.7.82 and went a fly today. As usualy rc signal lost randomly... then i download Litchi and its seems to be more stable. But i dont have enough time to try, but definitly more stable with litchi! Maybe not only the fw the piece of ****, maybe dji go also...
hey guys, so Can someone verify wich of the 1.7 is better? the 82 or the 84 ? because this 50 meter altitude on the 1.6 is making me crazy.
LOL OKJesus man, read back... both of them are a piece of s..t. read!
Hey Stavro , thanks for the info . In the OAKA region i cant get past 40-60 meters with any **** firmware... im sending it tomorrow back to Germany.
I'd fly it the way it comes and if you're happy, leave it as is. But I'd also check the app to see which FW version you have, just to know.Hello! I have bought a new Phantom 3 Standard that will come in the mail next week. (I have had one that was a camera error on it and i did a refund on that.) I have a quick question. Should I update the firmware on the new drone when i get it or should i just have it there it is??? Sorry for my English.
Okay thanks for answer.I'd fly it the way it comes and if you're happy, leave it as is. But I'd also check the app to see which FW version you have, just to know.
