- Joined
- Jan 18, 2017
- Messages
- 6
- Reaction score
- 1
- Age
- 61
i dont remember changing anything can i geMost people fly with stick mode 2. It sounds like you're using a different stick mode. You can change the stick mode in the "Remote Controller Settings" section of DJI GO.
I dont remember changing any settings. Could i get back to factory defaults?Most people fly with stick mode 2. It sounds like you're using a different stick mode. You can change the stick mode in the "Remote Controller Settings" section of DJI GO.
It was on mode 2. I cant start the engines manually either. Is that because im in beginner mode?There is no factory reset. It'll just take a few seconds to change the setting in DJI GO as I suggested above.
I tried it earlier outside, they only started when i used the app. No rotors on, they whirred up for about 10 seconds then shut downWhen in Beginner Mode, you will not be able to start the motors if your Phantom does not have a good GPS connection. The motors should start if you're outside.
What happens when the props are on and you're outside?No rotors on
Only had it a few weeks and last time it took off but the controls were inverted as i mentionedWhat happens when the props are on and you're outside?
