Need help tiits over to one side
wdy
Can someone tell me what I am doing wrong just got the phantom have never had it off the ground I have done the compass calibiation and it tiits over to one side and crashes..how do i fix this.
Thanks for the help
wdy
Thanks for the help
wdy
Sounds like you need to calibrate the IMU. (especially if you're getting anything other than a single green blink prior to take-off).
Read up on how to install the NAZA software and connect your Phantom up to a PC
http://wiki.dji-innovations.com/en/inde ... n_fails.29
[youtube]http://youtu.be/sWWinX3m23A[/youtube]
Also you need to be a bit heavy on the throttle at take off, too little will cause it to flop to one side.
Best thing to do is rev the motors a little bit let them all get to speed then go full stick once up back off . You'll get it
GL!
Would be good if DJI could put the "full throttle for liftoff" thing in the manual. I struggled with that also at the beginning.
intertronixlabel
