Naza-M v2 Application issue
Discussion in 'General Discussion' started by Glockindahaus, Aug 30, 2013.
  1. Glockindahaus
    I dont recall if I posted this in these forums before, but Im still having this weird issue. When I go to calibrate my Phantom or check it's settings within the Naza software, I cant check my compasses MOD setting accurately because the box that the setting is located in is truncated. Meaning, its shorter then the values above it so I cant see its full number!
    Has anyone else seen this problem? I've actually loaded this on two computers and both have the same exact display problem! Its so weird because this number is so important to calibrating the compass.
  2. jumanoc
    Go to Windows Screen Control Panel and change the Text Size to a smaller one.
    [​IMG]
  3. Glockindahaus
    That's not a bad idea. Ill give it a shot. Given that the number is supposed to be at least 4 digits to be within acceptable parameters, you would think they could simply modify the box so that it showed up like the ones above it. Regardless of the resolution of someones monitor..
  4. marcus_canada
    If it completes Cal and flies like a champ I couldn't care less what the numbers say :lol:
    The other thing is, I never go to the page just to check numbers, I figure if I am on the page, do a Cal anyway ;)
Similar Threads - Naza Application issue Forum Date
Naza 3.16 Application WTF? Phantom 1 Help Aug 15, 2013
naza m V2 with data link/ground station pro Other DJI Drones Jan 14, 2018
T15 with Naza M dropped out of the sky!!!!! General Discussion Nov 15, 2017
Start a New Conversation: Phantom 2 naza software and battery problem? Phantom 2 Help Nov 10, 2017
Convert Phantom 2 FC & NAZA M Lite to NAZA M V2 v4.06/v4.02 Phantom 2 Mods Sep 9, 2017
