Naza-M Assistant
In the Naza Assistant in Failsafe Settings what is difference between Landing and Go Home Landing?
In the first case it lands where it is, in the second case it attempts to return home (take-off point) then land.
I say attempts because weather, obstructions, battery, etc. can all interfere with the success of returning home.
In both Failsafe and Go Home Landing they will ascend 20m (factory default) turn and return home. The exception is that in Go Home Landing it is triggered by Critical battery level and not by moving the switch form GPS down to failsafe or as some do shutting off the RC unit. There is a Go Home check box in the battery configuration of the P2 assistant software just uncheck it. The problem I see in that option in that you could be under something when that is triggered and instead of go home it's off to the repair shop. Of course the same could be said for failsafe if you're flying out of line of sight.
20M above the home point.
That's nitpicking Steve :lol:
ODIN Reviews
