My P2V + Future Antenna MODS - Need Opinions
Hello guys.... Sorry for my bad english :(
I need of opinions about my future upgrade on my P2V + that will arrived there in brasil in the next weeks....
Mods will be done on Pilot side only, RC CONTROLLER and EXTENDER !
The parts that i have brought to upgrade my RC CONTROLLER and EXTENDER antennas is:
2.4ghz Booster
http://www.aliexpress.com/item/2014-Min ... 06772.html
5.8ghz Booster ( ONE USER SAY TO ME CHANGE THE CONTROLLER TO CE MODE, IF I WILL USE THIS BOOSTER, WHY ? DO NOT WORK USING FCC ? )
http://www.aliexpress.com/item/0-25-WEA ... 91151.html
11Dbi flat Antenna for RC Controller
http://www.aliexpress.com/item/FPV-5-8G ... 11332.html
2 Lipo Battery + T Plug To Dc Wire adapter
http://www.aliexpress.com/item/Txrdue-1 ... 82047.html
http://www.aliexpress.com/item/2Pcs-T-P ... 15663.html
PigTails Connector for Antennas MOD
http://www.aliexpress.com/item/5-pcs-lo ... 83445.html
http://www.aliexpress.com/item/5-pcs-lo ... 86041.html
13 Dbi antenna for EXTENDER
http://www.aliexpress.com/item/10PCS-80 ... 98172.html
Velcro Tape to PUT on the amplifiers
http://www.aliexpress.com/item/High-Qua ... 43136.html
What you guys thing ? With this upgrade kit i will reach a good range ?
Other modifications not ANTENNA relation...
CARBON FIBER PROPELLERS
http://www.aliexpress.com/item/Free-shi ... 83304.html
LARGE LANDING GEAR
http://www.aliexpress.com/item/1-Pair-T ... 53767.html
PROPELLER GUARD
http://www.aliexpress.com/item/Brand-Ne ... 86546.html
MULTI BATTERY CHARGER
http://www.aliexpress.com/item/DJI-Phan ... 27302.html
Thanks again
Gordy from youtube reply me about the CE MODE if use 5.8 ghz amplifier !
Gordy Guy6 minutos atrás
FCC mode is a amplified mode, if you amplify a amplified wavelength, the signal may not be clear and become garbled. It's like if someone screams in a microphone, if you boost more power the scream can be defening and some speakers cannot process the sounds. Put to CE mode you get normal and clear wavelength signal and the amp will provide a higher boost than the internal FCC boost.
Thanks Gordy Guy !
I know horizon antennas, but it is Soo expensive :( !
And i search for a cost x benefit for me !
Tahnks
