Mako79 said:syotr said:Check the wiring to the motor from the ESC you replaced. You likely have two wires swapped.DattaGroover said:During a normal flight with my P2, using a Taranis controller, it had red & green lights on normally, when it started a return to home run, completely out of my control. No big deal, but I wanted to land it myself, and get the camera angle right. My controller was 100% unresponsive, so I turned it off, then back on. At which point one of the motors did a full reversal.
It tumbled down to a very hard landing, ruining the shell. After replacing the shell (and one of the ESCs) I got it all back together, re-calibrated, but one of the motors still spins the wrong way.
Any idea what could possibly cause this, and how do I fix it?
Many thanks!
If a prop came off in flight, it does not mean the motor reversed. If an ESC fails and the motor comes to a sudden stop, then the inertia in the prop may spin it off.
If a motor comes to an immediate stop, would the props continue in the same direction and tighten further? A prop would only come off if the motors spin in reverse - correct me if im wrong..
Props will continue to go in the same direction, but will loosen.
