My ground markers
I thought I would share the ground markers we fabricated at my company. See photos. These markers are made of 24" x 24" x .25" plexiglass. We glued four (4) 12" x 12" checkered vinyl squares ( https://www.amazon.com/gp/product/B004GF5492/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1) to each marker. We then mounted a screw hook in the middle of each marker and cut a hole in each for carrying purposes. Four (4) small rubber legs were mounted to each marker to give clearance from the screw hook nut on the underside. We use these markers to confirm scale. I suppose one could use these for temporary ground control points (as long as they are not moved.). The purpose of the screw hook is so a single person can run a tape measure from one marker to another without assistance from another person. We have about $40.00 in materials wrapped up in each marker. Plywood could be used to reduce costs, but we decided on plexiglass for it's weather-proofing characteristics.
OK.......nice job.....nice pictures too.......Now how are they used....with the Drone is it for Real Estate and to show footage..from the air ect.
I work in the environmental consulting and engineering business and we use drones to collect imagery for 2D orthomosaic maps, topographic maps, 3D surface models and for determining volumetric calculations (soil cuts, fills, stockpile volumes). We also use DroneDeploy flight software and their cloud-based mapping software. The ground markers are used to confirm the relative accuracy of our 2D orthomosaic maps. We usually space the markers 50 ft. apart. If we need high absolute accuracy, as in most of our topographic maps we produce, we use ground control point (GCPs). Though these markers can also be used for GCPs.
I work in the environmental consulting and engineering business and we use drones to collect imagery for 2D orthomosaic maps, topographic maps, 3D surface modeling and for determining volumetric calculations. We use DroneDeploy flight software and their cloud-based mapping software. The ground markers are used to confirm the relative accuracy of our 2D orthomosaic maps. We usually space the markers 50 ft. apart. If we need high absolute accuracy, as in most of our topographic maps we produce, we use ground control point (GCPs). Though these markers can also be used for GCPs.
All of that is intriguing. I wish I could get into that type of work.
Thank You sooooooooooooo much for the explaining of the nicely made "ground Markers".......i appreciate your reply Thanks.
Our core business is the investigation and remediation of contaminated soil and groundwater. Not knowing your background, most people in environmental consulting/engineering firms have college degrees in environmental science, environmental engineering, chemical engineering, civil engineering, chemistry, geology or hydrogeology.
Reactions: FlyAlongside
mehow
