My gimbal doesn't move at all - help!
Help!!! I haven't used my P2 for like 2 Weeks as I waited for a replacement GoPro. Yesterday when i started the P2 - the gimbal went a crazy, same as some other ppl have posted. I turned it off as it didn't look to good, and now when i turn it on it doesn't move at all..
I tried short the pins as described in below thread, re-flashed the firmware (had to use version 3.0 on the phantom 2 software as 3.2 kept saying no updates availible). The light is green, It looks like all the cables is connected. Any ideas?? This sucks!
http://www.phantompilots.com/viewtopic.php?f=5&t=14362
Go into the phantom assistant (not the controller one) with your phantom and controller on and then calibrate the X1 switch. You may have to move the switch multiple times to get the calibration right.
I had something similar happen (it moved only a tiny bit) and once I calibrated the x1 it has been fine.
Hope that helps
DJIlvr67
