No, you need to adjust your exposure. If using auto exposure, try adjusting the exposure compensation to -0.3 EV - -0.7 EV.Is this a case of using filters in the lense.
Will have a go later if this weather changes. What an absolute shite summer we have had.No, you need to adjust your exposure. If using auto exposure, try adjusting the exposure compensation to -0.3 EV - -0.7 EV.
Where are you based? Your vid looks like it might be the U.K.?Will have a go later if this weather changes. What an absolute shite summer we have had.
Yes I’m based in Manchester U.K.Very bright and washed out. If you have auto exposure set touch the screen in the DJI Go app. you should see a + symbol with a circle around it, touch it and it should adjust. You can rotate the right knob to adjust the brightness also, I had a tendency to over correct so it would look good on my tablet but washed out on the video, I have corrected that and use the color of the sky as a point of brightness reference. Another suggestion is to use the RAW recording feature which can be edited to your preference.
