motors will not turn on after firmware update
Hey guys maybe i'm just dumb and missing something obvious here but last night I updated my firmware for the phantom 2 and transmitter. Since then I have also added an immersion rc video tx as well via the plug and play cable. Went to turn it all on today and everything powers up as usual including my gimbal except for when I go to power up the motors nothing happens. Is there something obvious I could have done to make this happen. Any help is appreciated, thanks!
I've heard that sometimes during/after the previous upgrades the transmitter 'Mode' switches to Mode-1.
Hook back up to your computer and check to see. You (obviously) want to select Mode-2 if it has changed.
#1 any change in led lights
#2 if so did you calibrate RC tx in RC Assistant Software then hooking up to phantom with phantom assistant to teach it the rc's full range of controls?
Ok great thanks for the help guys! I did check and make sure it was in mode 2 which is was. I also recalibrated it and that seemed to do the trick.
irish_phantom
