Motors power up fine, but P2 won't take off!
Discussion in 'Phantom 2 Help' started by IslandFilms, Jul 27, 2015.
  1. IslandFilms
    After a recent crash disabled one of my ESCs and took my P2 out of commission, I just replaced all four ESCs and all four motors (I live in a rusty climate -- it was time for a refurbish).
    Now, my P2 powers up fine, and all four motors spin fine, but the P2 won't take off -- it's as if it doesn't have enough power.
    Any idea what could be the problem?
  2. Duke
    SW Lower Michigan
    I have a couple questions for you, Did you buy separate esc's? What I mean buy that were the esc's and motors separate? Or did each esc come wired to a motor? Second Question looking at the Phantom in front of you, Stripes on arms facing you battery should be on opposite side of quad tell me which direction it takes to unscrew those blades with the stripes in front of you on the
    RIGHT?
    LEFT?
    Thanks ~Duke
  3. IslandFilms
    Thanks for your help, Duke. To answer your questions:
    I bought the ESCs separate from the motors.
    These are the ESCs I purchased:
    http://www.amazon.com/gp/product/B00K456LIG?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
    And these are the motors:
    http://www.amazon.com/gp/product/B00PL72ZJG?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
    http://www.amazon.com/gp/product/B00PL7078W?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s01
    As for your second question,
    Right blade: clockwise
    Left Blade: counter-clockwise
  4. barefootbeachcombing
    US
    Are you sure that you put the motors in the correct places on the Phantom?
    As Duke asked, which direction do each of the motors spin?
  5. Duke
    SW Lower Michigan
    Well as I am facing mine Stripes facing me , The right motor tightens CCW and the Left is CW. If yours are different from that I think they are backwards. Now ya might as well taker apart and when Your in there quad facing you with the stripes take me a picture of the mtr and esc on the right striped arm then the left and post them. I think we can tell you if your esc's are wired correctly.
  6. IslandFilms
  7. IslandFilms
    I realize the problem. I wired all the ESCs identically, whereas I should have them alternating.
    Thanks for your help, Duke!
    Duke likes this.
  8. Duke
    SW Lower Michigan
    Not a problem mate! Gimmie Some! ;)
  9. jason
    Commerce Twp,MI
    Your CCW motors are wired wrong thats why it won't liftoff. The CCW motors should be wired from top to bottom blk, yel, red but you have them wired the same as the CW motors.
  10. Bog
    Bog
    Did you connect back with software and verify the mode your tx is in? Mine did the same after a Cali...connect again and verify by the phantom and the tx
  11. jason
    Commerce Twp,MI
    His motors were wired wrong.
  12. Bog
    Bog
    Jason , in the picture above are the markings on the picture the correct pattern? Is there a document that demonstrates how the wires should layout from naza to all components
  13. N017RW
    Palm Beach Co.- FL
    With respect to the motor wiring...
    If you reattach the motor incorrectly the WORSE thing that can happen is it spins backwards or opposite of your intent since there are both CW and CCW versions.
    Don't get concerned with the colors as much as the direction.
    If you wired it and it is backwards from what you want, swap ANY TWO wires to reverse the direction.
    The colors of those two wires does not matter.
  14. jason
    Commerce Twp,MI
    I posted a photo and the motor on the right is ccw look how it's wired. I've been for over 14 months wired this way. CCW Blk, Yel Red CW Blk Red Yel
Similar Threads - Motors power fine Forum Date
P3 Standard main boards with motors, LED and power connector Classifieds May 3, 2017
P3 Standard main board with motors, LEDs, power connector $80 Classifieds Apr 10, 2017
motors won't power on / light out Phantom 1 Discussion Jan 3, 2017
"Limp Gimbal" Motors Are Not Getting Power BUT Camera Works Phantom 4 Help Jul 30, 2016
Advanced Motors will not power on Phantom 3 Help Apr 8, 2016
